Adding a new map server
stefano6413
Re: Adding a new map server
Сообщение stefano6413 »
Ivan30 писал(а):
stefano6413 писал(а):Hello, my name is Stefano
Hello, Stefano
stefano6413 писал(а):The address wms is:
http://idt.regione.veneto.it/WMS_c0101_ ... ce.svc/get
Those service? http://idt.regione.veneto.it/app/metacatalog/ and what do you want?
ortofoto
http://idt.regione.veneto.it/erdas-iws/ogc/wms/Ortofoto?SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=NordItalia_alpencors_veneto_gbo.ecw&FORMAT=image%2Fjpeg&WIDTH=1180&HEIGHT=388&BBOX=1579743.9042706045,5020395.175083376,1836112.9498136856,5104634.444371692&CRS=EPSG%3A3003&STYLES=
or layer
http://idt.regione.veneto.it/wms_c0101_cartografiabase/service.svc/get?SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=C0101101_LOTTI_DBGT,C0101061_IGM100000,C0101051_IGM50000,C0101041_IGM25000,C0101031_CTR20000,C0101021_CTR10000,C0101011_CTR5000&FORMAT=image%2Fpng&WIDTH=1180&HEIGHT=388&BBOX=1579743.9042706045,5020395.175083376,1836112.9498136856,5104634.444371692&CRS=EPSG%3A3003&STYLES=,,,,,,&TRANSPARENT=TRUE
I would like layers
tank you
Ivan30
Благодарил (а): 60 раз
Сообщение Ivan30 »
well, your service use another projection http://spatialreference.org/ref/epsg/mo ... ly-zone-1/
I cant create .zmp correctly, only this
veneto.zmp.zip
stefano6413
Ivan30 писал(а):well, your service use another projection http://spatialreference.org/ref/epsg/mo ... ly-zone-1/
veneto.zmp.zip
hello ivan
thank you very much anyway for the time that you lost to prove
jeanbon
Благодарил (а): 7 раз
Сообщение jeanbon »
Hi,
please find after here the Veneto Maps
veneto.zmp.7z
(3.95 КБ) 338 скачиваний
and
VenetoOrto.zmp.7z
(2.4 КБ) 313 скачиваний
The projection EPSG:3857 is available for the server
Jeanbon
Maximuz
[Help] Adding a new map server (difficult high)
Сообщение Maximuz »
Buen dia, regreso a este foro despues de intentar varias veces poner una capa llamada cdenue14, sin exito, no se que estoy haciendo mal, hace tiempo intente ponerla ni antes ni ahora e podido, quizas tenga algo mal
Good day, I return to this forum after I try several times to put a layer called cdenue14, unsuccessfully, not I'm doing wrong, while I try to put it, not before, not now I could, maybe I have something wrong
http://gaia.inegi.org.mx/NLB/tunnel/wms/mdm6wms?map=/opt/map/mdm60/mdm61vector.map&LAYERS=cdenue14&FORMAT=image%2Fpng&MAXRESOLUTION=4891.969809375&MINZOOMLEVEL=5&ZOOMOFFSET=5&TATO=0&LAYERNAME=&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FIRM=419&SRS=EPSG%3A900913&BBOX=-11656513.59485,2757181.1075925,-11647341.151458,2760243.3660377&WIDTH=1920&HEIGHT=641
 [b]Geturlscript.txt[/b]
var
  Host: string;
begin
  Host := RegExprReplaceMatchSubStr(GetURLBase, 'gaiamapas\.inegi', 'gaiamapas' + IntToStr(Random(4)) + '.inegi');
  Host := RegExprReplaceMatchSubStr(Host, 'gaiamapas0\.inegi', 'gaiamapas1.inegi');
  ResultURL := Host + '&FORMAT=image%2Fpng&TATO=0&LAYERNAME=&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=' +
    RoundEx(GetLMetr, 8) + ',' + RoundEx(GetBMetr, 8) + ',' + RoundEx(GetRMetr, 8) + ',' + RoundEx(GetTMetr, 8) + '&WIDTH=256&HEIGHT=256';
end.
 [b]params.txt[/b]
[PARAMS]
GUID={cdb02f5c-9e5e-4823-90cc-599960b20ff9}
name=Denue
name_en=Denue
ParentSubMenu=gaiamapas
ParentSubMenu_en=gaiamapas
DefURLBase=http://gaia.inegi.org.mx/NLB/tunnel/wms/mdm6wms?map=/opt/map/mdm60/mdm61vector.map&LAYERS=cdenue14
EPSG=3785
NameInCache=Denue
ContentType=image/jpeg
Maximuz писал(а):---------Español----------------
Buen dia, recurro en busqueda de su ayuda para añadir un servidor de mapas, que por motivos desconocidos no he podido incluir en SAS Planet, he hecho pruebas sin exito y cuando visualizo las capas de los mapas en gvSIG, no se visualizan los mapas como aparece en el portal web, ademas he hecho de todo para hacelo funcionar con SAS Planet sin exito, por lo cual estoy recurriendo en su ayuda, espero y ustedes me puedan ayudar con esto.
Website: http://goo.gl/aHwg2q
Web Map Service: http://goo.gl/lO4vrS
El mapa del portal web, esta mas presentable que el wms, si se pudiera añadir el portal web estaria mejor.
Gracias por todo.
----------English------------
Good day, I appeal seeking your help to add a map server, which for unknown reasons I have not been able to include in SAS Planet, I have been tested without success and when I visualize the layers of maps in gvSIG not maps as shown on the website are displayed've also done everything for viewing on SAS Planet unsuccessfully, so I'm resorting to his aid, and I hope you can help me with this.
The map web portal, is more presentable than the wms, if you could add the website would be better.
Thanks for everything.
