Spanish Translation
Re: Spanish Translation
Commited: https://bitbucket.org/sas_team/sas.tran ... e121c945e9
Which character did you try to insert before "Si" here?
When I'm trying to update translations by gettext tool, it want to replace this symbol by something "non-text" and wrong as I think. Is it better to remove this "\v" and make simple translation "Yes" -> "Si"?
Si! :)
Yago
Сообщение Yago »
Hi all
Attached .zip file with es.po and es.mo translated to Spanish (95%)
Thank you all.
Yago
SAS.Lang.Translate.Es.160125.zip
(56.35 КБ) 261 скачивание
Commited: https://bitbucket.org/sas_team/sas.tran ... 62d7e36580
Problem with "Yes" -> "Si" translation is still there.
zed писал(а):Problem with "Yes" -> "Si" translation is still there.
Fixed: https://bitbucket.org/sas_team/sas.tran ... c23abba67c
Yago
Сообщение Yago »
Hi All
Attached zip file with es.mo and es.mo
Some translated lines, some revised and some back.
I think that the next version will be after a new release.
Yago
SAS.EsLanguageTranslate160127.zip
(56.57 КБ) 238 скачиваний
Yago
Сообщение Yago »
Hi All
Regards
Yago
SAS.EsLanguageTranslate160227.zip
(56.69 КБ) 277 скачиваний
Commited: https://bitbucket.org/sas_team/sas.tran ... e18192f021
Your .po file was outdated. You must always translate latest version of .po file. Link to the latest version is: https://bitbucket.org/sas_team/sas.tran ... et/tip.zip
Yago
Сообщение Yago »
Attached zip file with es.po and es.mo files.
I hope to have done this time things well!
Note: msg "Disable by map params" non exist in english and spanish .po files (See: Settings/Options>>>Map settings)
Yago
SAS.EsLanguageTranslate160315.zip
(57.92 КБ) 237 скачиваний
