tstal
Сообщение tstal »
Tolik писал(а):
tstal писал(а):вот здесь (в самом конце) я выложил ту область, которую пытаюсь скачать ("окресности.hlg" ) .
viewtopic.php?f=2&t=1378&p=23110#p23110 Может у вас получиться выудить все зумы?
То есть нужен спутник гугла? (Я тут, типа, телепат).
Вас просто забанили. Нельзя выкачивать слишком много сразу.
выходит что можно брать только один зум за раз? и область поменьше....
omek07 писал(а):Tolik its not the Google Translate
Its my English
My English is crap
zOn писал(а):я английский по комп.играм учил )
А лично мне тутошний суржик в этой теме уже третий день рвет все шаблоны... Пешыте ысчо!! :lol:
omek07 писал(а):What is the best resize algorithm on the sas planet ???
The best one depends on your preferences and needs. You may want to try some and select the one you like at most....:)
PS: you may write on English - please, do not brainfuck us via that GoogleTranslate... Those who need the translation[s] - may proceed to the G.T. and be enlighted by themselves.
PPS: we have the very special thread for the very beginners of SAS.Planet: CLICK, please post the newbie's questions there and keep this thread civil.
omek07 писал(а):now i want to resize this tiles from z18 to z17
I did not understand why.
You could generate all zooms in Global Mapper at once.
omek07
Сообщение omek07 »
Yes i know but it takes to long
omek07 писал(а):Yes i know but it takes to long
There is nothing free on this world - somehow you got to pay for something you need. Pay by your time at this case... :lol:
Hey, why just not re-download z17 from the server? Thus you'll have z18 AND z17 along, without the needs of recreating+waiting the thing... :)
omek07
Сообщение omek07 »
What do you mean by this "Hey, why just not re-download z17 from the server?"
The name of folders and jpg files is different from z18 to z17
omek07 писал(а):What do you mean by this "Hey, why just not re-download z17 from the server?"
In case you've downloaded the map as a tiles - just re-download another zoom from the server, that's it.
In case you got your map as a single image and have tiled it by yourself - just resize the initial single-file map to a half-sized one (one-time operation per whole map, just a few seconds to go), correct the reference\projection file and repeat the tiling. You'll get an upper zoom.
Or just generate those upper zooms in SAS.Planet - but then you must wait a bit longer...and this will not require you to understand the whole process in details (say, this will teach you nothing). Pick your choice. :roll:
alez
Изменения положения уже сохраненных полигонов
Сообщение alez »
Вопрос: имеется ли возможность впоследствии корректировать положение сохраненных полигонов, путей?
И еще пара вопросов:
Virtual earth и карты Шуберта реально смещены относительно друг друга, где то в FAQ видел упоминание что необходимо перепривязать карты. Подскажите пожалуйста как это сделать? В папке с картами посмотрел все файлы но так и не нашел в каких могут быть прописаны привязки.
В каком файле метки для переброски их на другой компьютер? Насколько я понял это два файла Categorymarks.sml marks.sml ? Правильно?
alez
Re: Изменения положения уже сохраненных полигонов
Сообщение alez »
По редактированию меток разобрался сам- правой кнопкой мыши на полигоне, выбрать редактировать.
alez писал(а):перепривязать карты. Подскажите пожалуйста как это сделать?
Правильно.
Перепривязать непросто: предлагается склеить в большой файл, привязать его тем же Глобал Маппером и снова порезать на тайлы. Только результат вряд ли будет сильно лучше: у Шуберта не было спутника и даже самолёта.
