Bing Maps with Satellite + Road
mistergiloo
hi
I am very new with SASPlanet and I use NoniMapView and I can download tiles from bing Maps with Satellite + Road (together)
do you know where I can make the same thing with SASPLANET ?
thanks
thanks
Ivan30
Re: Bing Maps with Satellite + Road
yes, you can
edit in Bing.zmp (Maps/sas.maps/Bing)
GetUrlScript.txt
and params.txt
where are you from? France? ask jeanbon about maps of France
GetUrlScript.txt
ResultURL:=GetURLBase+res+'?mkt=fr-fr&it=A,G,L,LA&shading=hill&og=66&n=z'Код: Выделить всё
DefURLBase=http://ak.dynamic.t3.tiles.virtualearth.net/comp/ch/where are you from? France? ask jeanbon about maps of France
Последний раз редактировалось Ivan30 21 ноя 2014, 01:38, всего редактировалось 3 раза.
mistergiloo
Hello
Yes I am french from Paris and I don't need maps from france.
I need Bing maps (satellite and roads together) from russia, kazakhstan, Uzbekistan, Kirgizstan, China and Mongolia.
I want to organize a motorbike off-road trip from moscow to vladivostok passing through theses countries only on off-road tracks
So I need to find 25000 km of tracks without going first
So for me the only solution is to download first millions tiles of Bing maps of all theses countries (-> zoom from Z1 to Z18 or Z19) in France in order to use them when I will be in theses countries without internet connection cause I want to make bivouac every nights.
so Zed I can't do as you say because I want to download all tiles.
the download option don't allow to download also Layers Maps.
I don't have the same window setting like you cause I don't have Params.txt and Geturlscript.txt and info.txt Options. do you know why ?
I run SAS.Planet.Release.140505 on a macintosh using "PlayOnMac"
Ivan30 : I did what you say and it works well thank you.
with Nonimapview, the configuration of Virtual Earth satellite + Road is :
http://h*RND*.ortho.tiles.virtualearth.net/tiles/h*VEId*.jpeg?g=1265&mkt=*LAN-LAN*
I don't know anything with this language but is it interesting for you ?
see attachment file
thanks for everything and for your quick response.
gilles
see attachment file
gilles
You can download any map or layer:mistergiloo писал(а):so Zed I can't do as you say because I want to download all tiles.
Because version 140505 is out of date. Current version is 141111.mistergiloo писал(а):I don't have the same window setting like you cause I don't have Params.txt and Geturlscript.txt and info.txt Options. do you know why ?
mistergiloo
Hi Zed
thanks for your quick answer; I gonna download current version
but about Hybrid (Google); I have been told that with Google it is not possible to download too much tiles cause if you do you will be blocked to download.
that is why I use Bing maps. you can download during many days without problems.
is it correct or do you have a solution to download Google maps during 1 week 24/24 h ?
thanks
thanks
I just reply on this:
And yes, Google may ban you for a day or so, if you download too match data. But you can change your IP (reconnect to your internet provider if you have dinamic IP or use some proxy) and resume your download.
Google is not only one layer with roads. You may try Yandex/OpenStreetMap/Wikimapia and others. Google was an example.
and this is not true. Options in SASPlanet allow you to download layers.the download option don't allow to download also Layers Maps.
mistergiloo
Hi Zed
Yes you are right about Layers Maps. I didn't see the stitch Option of downloading menu.
Yandex Satellite + layer Hybrid Yandex is perfect; better than Bing
do yo think there no problem to download a lot of data without to be ban ?
and how to do to have European Names of cities, roads etc… ?
thanks
thanks
mistergiloo писал(а):do yo think there no problem to download a lot of data without to be ban ?
I don't know...mistergiloo писал(а):and how to do to have European Names of cities, roads etc… ?
Example tile: http://vec04.maps.yandex.net/tiles?l=ma ... lang=en_USmistergiloo писал(а): and how to do to have European Names of cities, roads etc… ?
So you can change Map Settings - URL like this:
http://vec01.maps.yandex.net/tiles?l=map&lang=en_US&x=
