bartho писал(а):New version directly translated from sas_team-sas.translate-9c15e5719345 and tested with SAS.Planet.Nightly.160604.9417.
Commited:
https://bitbucket.org/sas_team/sas.tran ... e3f0eafaec
bartho писал(а):The new function "Save as separate placemarks..." is only corresponding to pathes.
For the polygon, it is logically not actived.
This option works with MultiGeometry (MultiPath/MultiPolygon). If you create MultiPolygon via Merge Polygons you be able to split it back to the single polygons:
bartho писал(а):A little problem, in "Distance Calculation", if you use the function "Split line", the function "Save as separate placemarks..." is actived but without result.
Not really important.
Yes. This is a bug. Reported:
viewtopic.php?f=61&t=2820&p=42975#p42975
bartho писал(а):Another anomaly :
With "Placemarks..." "Add Placemark".
If you cancel, the point with arrow is still here. You can’t really cancel it ! You must save it first and then cancel it with right click or other function in the Placemark Manager.
No, you can unpress "Add Placemark" or press "Move" button:
