GoogleEarth tiles
neolite
GoogleEarth tiles
Сообщение neolite »
Hello,
I am trying to read tiles from Google Earth.
Earth (Mercator) returns a error: no internet connection.
Earth (GECache) returns: bad file.
I am using the latest GoogleEarth 5.2.1.1547 and SASPlanet 100707.
The map parameter URL for Google (Mercator) is: http://localhost/flatfile?server=1&proj ... r=0&hist=0
The GoogleEarth maps are sometimes newer then google maps, so I would be very happy to make this work :)
Thanks !
Re: GoogleEarth tiles
neolite писал(а):Hello,
Thanks !
SAS.Planet currently has some tech.issues while working with the latest GE5.2 cache due to internal changes in the cached image structures happened on v.5.2. Stay tuned.
Alternatively, you wanna switch to an earlier v.5.1 (which works fine BTW) and re-obtain your cache, OR uncheck the "Use compressed textures" in GE5.2's settings (as shown here) - and again, re-obtain your cache. Voila! :roll:
neolite
Сообщение neolite »
With uncompressed textures in the 5.2 version it is working, THANKS !!!
Is there any way to automatically fill the cache with a specifyed area and zoom level or do I have to do this manually ?
neolite писал(а):Is there any way to automatically fill the cache with a specifyed area and zoom level
Here we go.
English langpack is included, AFAIK.
neolite писал(а):or do I have to do this manually ?
Only if u got PLENTY of free time to be wasted to... :lol:
neolite
Сообщение neolite »
Thank you SO MUCH !
Really great what you are doeing here !!!
