upload instead of download
unpointeul
Сообщение unpointeul »
Hi all.
I'm using sas planet in my windows server
and I'm using a simple VPS (2GB RAM AND 30GB HDD)
i download some area ( after a difficult time , change my proxy till end download is completed )
now I have a 15 GB cash in sas planet
well i don't have enough storage to build an ECW file of my area.
i think there are two option here :
1- upload the whole sas planet folder ( including 15 GB cash ) to my dropbox
then download that to my pc and build an ECW of my are
well, this option failed , and the cash does not work in my pc so i have to download again
2- another option that i think is build an ECW file of my area on my windows server but don't chose one of my HDD drives in my server and instead of that chose my dropbox
finally the question is
i don't know how can i chose dropbox instead of my drive ? :cry:
thanks all
QuickBird
Благодарил (а): 9 раз
Re: upload instead of download
Сообщение QuickBird »
sincerely, I don't understand what the problem is, 15Gib is not even a thing, 15 Terabytes would be. There are cheap removable drives. One SasPlanet install can also operate between several drives by changing paths for Cache, Zmp and Paths.
If by chance you will try to translate LARGE FILES between file formats within SASplanet you will encounter that it sucks up all your memory, but that is a SasPlanet bug.
