Access Violation error when Exporting to
BillyJ
Сообщение BillyJ »
Latest Stable Build - 200606.10075
When I make a selection and use the Export feature to export to .KLM, I get the following error:
"Access violation at address 00E62F53 in module 'SASPlanet.exe'. Read of address 00000000."
There is no other information available. I can export to other formats fine, but I always get this error with .KLM.
This happens on two different computers (Windows 10, x64).
I also went back and tried the previous stable version - 190707 - and I get the same error.
Can anyone help?
Update - I tried this on a 3rd computer with Windows 7, and received the same error. All with different Satellite Imagery - Google Earth, ESRI ArcGIS.Clarity, etc.
BillyJ
Re: Access Violation error when Exporting to
Сообщение BillyJ »
I may have found part of the problem.
When I go to the Export tab, there is a drop-down for Map selection.
This drop-down is empty. I cannot select a map.
Is this possibly causing the error?
Mas
Благодарил (а): 11 раз
Сообщение Mas »
Same problem with Export format JNX; no maps selection on nightly version.
Such error should be reported in Bug Tracker (if not done yet).
Dumps should be collected first using SASPlanet.Debug.exe
