Adding Cache
abrogard
Adding Cache
Сообщение abrogard »
How do I add an existing cache to a new instance of Sasplanet?
I had an old version with much downloaded in the cache.
Now I have installed the newest version and its cache is empty.
And I don't see how to make it use the old cache.
And I don't see how to make it use multiple caches.
And I don't see how I can simply copy the old cache to the new instance.
Can someone help me with this please?
Gma
Благодарил (а): 35 раз
Re: Adding Cache
Сообщение Gma »
You can change the path to the cache in Settings—Cache
abrogard
Re: Adding Cache
Thank you for that.
Do you know of any way to join the two caches together?
caddis
Благодарил (а): 12 раз
Re: Adding Cache
Сообщение caddis »
abrogard писал(а):Thank you for that.
In every new version of SASPlanet, I copy the cache from the previous version into the folder of the new version. There is no need to merge caches. The advice is to have the cache in SQLite3 format.
abrogard
Re: Adding Cache
That's very good but it doesn't solve the problem of 'joining two caches'.
I have a sasplanet install on each of three machines.
They each have their own caches of course and each contains different 'saves'.
I would like to join them all together so that whichever machine I am using I have access to all that saved material.
I have much cached at level 21. Horrific amount of time went into downloading that.
caddis
Re: Adding Cache
Сообщение caddis »
abrogard писал(а):That's very good but it doesn't solve the problem of 'joining two caches'.
I see!
What format are the various caches in? If they are in tiles, it should be enough to have the caches with the same tiles on all three PCs, copying them from one to another while maintaining the same directory structure. It could be a tedious task.
However, if they are in SQLite3 format (recommended format), I don't think merging the caches is possible.
I have another way of operating though: I have a PC with updated SASPlanet where I download and save the images in the cache. Then, periodically, I update the other PCs by making an exact copy of SASPlanet from the first PC.
Because it's not just the cache that needs to be updated, but also the placemarks with photos and links, new ZMP maps file,...
abrogard
Re: Adding Cache
Hello and thank you for your reply.
Yes. Your way of operating means you only download on one machine doesn't it? For downloading purposes you only have the one. The other machines will automatically download some tiles as you browse around but that will all get overwritten when you put the latest version on top won't they?
Have you any idea how we can reach the programmers for Sasplanet?
caddis
Re: Adding Cache
Сообщение caddis »
abrogard писал(а):Hello and thank you for your reply.
Hello!
Yes, that's correct.
Regarding developers and other important information, you can take a look at the FAQ (section_ Wish list, bugs and errors) using the translator.
viewtopic.php?f=4&t=986
mate
Re: Adding Cache
Сообщение mate »
abrogard писал(а):Do you know of any way to join the two caches together?
Operations — Cache Manager
