Can we Insert a node in a path?
abrogard
Сообщение abrogard »
I can only find a way to add nodes but not insert them. Wherever I click I will get a node but it will be an extension, of course, the code believes I want to extend the path. But I just want to put more nodes IN the existing path so that I can make it go round corners. Is it possible?
Re: Can we Insert a node in a path?
Yes. Click on an existing node, then click somewhere else - the new node will appear between selected node and the next one.
abrogard
Thank you, Tolik. It works just as you say. I feel a fool for not finding it. I covered half my screen trying... dozens of clicks.... found it impossible..
Just didn't do it right.
So easy and simple. Thank you very much. This helps me a great deal with what I do.
