Hello,
I just wanted to report a bug (I thing):
When the GPS is on (and center map selected), if I try to move or zoom the map (have tested with google maps sat view) I am getting a overflow error: invalid floating point operation.
I guess the map moveing/zooming should be disbled if the gps is on, or if you move/zoom the map then the gps should be disabled untill you put it on again.
Bug: GPS on + move/zoom
Re: Bug: GPS on + move/zoom
neolite писал(а):When the GPS is on (and center map selected), if I try to move or zoom the map (have tested with google maps sat view) I am getting a overflow error: invalid floating point operation.
Thanks. Our testing team will check it out, and in case of positive - will try to fix it soon. Please come back recently and check for updates.
- Vinil_37
Выскакивает эта ошибка после каждого перемещения и зуммирования. Сначала прога ещё как-то работает, но потом виснет.
Нормально всё работало в версии 90825.
The bug has been fixed in Version 90914, GPS is now working excelent.
Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RESOLVED:CLOSED
