Placemarks export
neolite
Placemarks export
Сообщение neolite »
Hello, in what format are the Placemarks saved (Placemark, Path, Poligon) ?
Is it possible to export/convert them to some commonly used format ? Like GPX (GPS Exchange Format), KML, ESRI shape file, or something similar ?
The Import (KML) works very well, a export function would also be very nice :)
neolite
Re: Placemarks export
Сообщение neolite »
I am playing with the Placemarks again ... and have noticed a small (not really) bug.
The Language I use is English.
Goto "Placemarks"->"Placemarks manager"
bellow "Categories of Placemarks" the tooltips on the buttons are: "??????????" "??????????" "Delete"
bellow "Placemarks" the tooltips on the buttons are: "??????????" "Delete" "Goto chosen object" etc ...
They are in total 3 strings that I guess have the wrong font/language when English is selected in the Program settings.
ps. Are you at least considering to implement (sometime in the future) a Placemarks export function ? :)
